Just tried Interference tool but the checkbox for keep doesn't select. Used a simple cube and cylinder.
I'm on a iMac 10.8.4
Solved by donsmac. Go to Solution.
There is a note that pops up if you stay hovered over check box. Says 'it's not supported in parametric. I did not see the note before cause I never left the mouse hovering over the check box long enough. Works fine if you are not in history mode. Also noticed it's not supported in base feature either. All good.
