Can't install update (May 2014)
8 REPLIES 8
Message 1 of 9
rpagewood
625 Views, 8 Replies
All I get is this
Any ideas how to get the install working?
8 REPLIES 8
Message 2 of 9
keqingsong
in reply to: rpagewood
@rpagewood wrote:
All I get is this
Is this happening after you've launched the new installer?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 9
sanjay_jayabal
in reply to: keqingsong
Sorry to hear that the update didn't work correctly for you.  Did you get a liveupdate notification that forced you to get the update?  At what point are you seeing this screen?
best regards,
Sanjay Jayabal
Message 4 of 9
rpagewood
in reply to: sanjay_jayabal
this comes up when I try to run the install file.
Message 5 of 9
sanjay_jayabal
Is there a number I can call you at to discuss this?
best regards,
Sanjay Jayabal.
Message 6 of 9
jinhai.zhu
Which windows version are you using?
It seems this error may relate to Cache when installing. Can you have a try to clean some cache under
%temp%\7ZipSfx.***
%temp%\Autodesk
Gavin
Message 7 of 9
rpagewood
in reply to: jinhai.zhu
niether are there now. Still can't install
Message 8 of 9
matt.pooley
The specific error you are seeing is being triggered by an Internet Explorer based browser control embedded within the Streaming install application. It is possible you are seeing this because of security restrictions applied to Internet Explorer on your system. I was able to reproduce your symptoms by disabling Active Scripting inside Internet Explorer, can you try enabling this option for the relevant security zone and running the installation again ?
Matt
Message 9 of 9
rpagewood
in reply to: matt.pooley
worked!
thanks for that
