Hi
I can't install. It stalls on "Preparing" splash screen for long time, and then this message comes:
I'm behind a http proxy I should say. Does it honor those settings?
Regards
- BJörn
Solved by bjorn.syse. Go to Solution.
Solved by jessica.t. Go to Solution.
Thank you very much for the script in the zip.
Unfortunatly it did not work. At home is OK.
Users behind any serious corporate firewall are going to run into this problem as well.
Hi Ivan,
It appears you are running from a network behind a web proxy that requires authentication using an unsupported protocol.
The bat file that was being used is to help the streamer connect to the proxy when other settings are not being detected. In this case the connection is fine, but the streamer is incompatible with the proxy.
The easiest work-around is to install Fusion while connected to another network that doesn’t have the same configuration (home, a coffee shop, a friend's house, etc.).
If you have already done this, please make sure that you updated your proxy information in the dashboard:
This can be found under the Menu > Preferences > Network.
I hope this helps! Please let me know how it goes and if we can further assist.
message show on my screen that "You have multiple instances of the fusion 360 installer running at the same time"....
please tell me problem
