Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Bug with extrude using "To" extends with "both sides"
1 REPLY 1
188 Views, 1 Reply
I have a simple model with two pipes as below
I then try to join the two pipes with a horizontal pipe via an axis as below. I select extents to be "To" and
select the right vertical pipe. The extrusion works and mates with the pipe.
I then extude to the other pipe and I get
It cuts through the body of the reference pipes. I have the model here in the gallery
https://fusion360.autodesk.com/projects/extrusion-bug-example
Tags (2)
1 REPLY 1
SallyYang
Thanks for reporting this issue to us, we have reported to our development team and will resolve it in future releases.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
