While I haven't been in Fusion 360 much, isn't there supposed to be a Settings button here? I'm using Chrome browser on a Windows 8.0 machine.
TIA,
JD
Solved by jdavis417. Go to Solution.
You are correct. I've seen this before but it was fixed just by rebooting. After rebooting the machine is it still missing?
Thanks for letting us know, and sorry for the trouble.
Can you recall what might have happened to cause this? A crash or other strange event?
Thanks!
Phil,
No, there was no apparent cause. The control failed to appear after a complete shut-down and re-start (the next day), then again after one re-boot. It took two re-boots before the control button reappeared.
The inconsistent problems are the worst, aren't they?
Respectfully,
JD
