Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Are material selections enabled in the beta?
2 REPLIES 2
510 Views, 2 Replies
Is it possible to change a solid body's material in the Fusion 360 Beta? When I try to using the 'Material' command (from the marking menu) I see lists of materials pop up, but all with a 'lock' symbol presented when my cursor hovers over.
Tags (1)
2 REPLIES 2
patrick.miller
Right-click the desired material and select "Assign to Selection". The lock is referring to whether you can edit the material.
Patrick Miller
User Experience Designer
Fusion 360 Learning
in reply to: patrick.miller
Thank you, that did the trick.
