Question 1: Are driven dimensions available in Fusion 360?
Question 2: How do I delete a sketch constraint?
Solved by herzinj. Go to Solution.
With respect to driven dimensions:
Reference and driven dimensions are not available at this time. However, you can drive dimensions through expressions in the parameters dialog with timeline is enabled, which may help. To access this dialog, select the "Change Parameters" command in the Modify panel of the Model workspace.
There are some IdeaStation post in about this if you would like to vote:
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/driving-dimensions/idi-p/5039950
With respect to deleting sketch constraints:
To delete a sketch constraint:
Step 1: select the sketch constraint (must be editing the sketch)
Step 2: press the delete key on the keyboard or right click and select delete while the sketch constraint is selected
I should note that you can use the “select other” tool (just linger on the left click button to access) to select tricky sketch geometry constraints. This may be helpful if you dealing with a really crowded sketch.
So how do you delete the coincident constraint between two rectangles? or even between two line segments of a rectangle?
I created a new post here so a solution can be provided.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
