Just been looking at the FAQs in 360 Mobile and it says you can view F3D files with it.
I can't find a way to get a .f3d file into my 360 account. Any ideas? Thanks.
I just tesetd and was able to view an f3d file on my iphone. I dragged and dropped the .f3d file to my A360 drive on my PC. Then in my mobile app I was able to view it.
I thought I would mention that you should also be able to upload it at https://360.autodesk.com/ if you do not have the desktop client installed. Hope that helps.
Thanks Nathan, but how do you get the f3d file out?
I can't export as f3d. Where are you dragging the file from?
To get an .f3d file on your machine, use the export archive feature. Then you can upload the file to Autodesk 360. Hope this helps!
