I uploaded 2 STLs and thre are permanently stuck in "Import - In progress". How can I cancel them and remove them? Thanks!
Solved by rishivadher. Go to Solution.
Hi, Jeff
Try this deleting the job.json file, close Fusion 360
For
mac
Users/YOUR_HOME_FOLDER/Library/Application/Support/Autodesk/production/JobManager360/200909132029047
Windows step 1, step 2 if 1 doesn’t work, and step 3 if 2 doesn’t work
1 - C:\Users\<User>\AppData\Local\Autodesk\Autodesk Fusion360\9T7HR93TCPCP\PLM360Cache\qa4001.autodeskplm.com\UploadQueue
2 - C:\Users\<user>\AppData\Local\Autodesk\dev\JobManager360\9T7HR93TCPCP\
3- %localappdata%\Autodesk\production\JobManager360\<id of the application you are running>
Best Rishi
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
