While working with Assemblies in Inventor 2011.A user is unable to open/view two parts of worm and a worm gear.
Only a worm is displayed.
The user can however see a worm and a worm gear under model browser.
What could be the problem and how can this be fixed.I have so far tried repairing the installation without uninstalling the software.
NB:
The user follows this path to open the above mentioned.
New-Design-Spur Gears-Worm Gears and accepts the default settings.
Spur and Bevel Gears open their assemblies without a problem.
Kindly assist.
Peter K'onunda,
Nairobi,Kenya.
Solved by SaintCrooner. Go to Solution.
I found a fix for the problem,....
The computer was also developing some problems, so we formatted and did a new installation.
Evereything now works fine.
