Hi all,
I need help figuring out what sort of hardware upgrades or possibly a new PC I would need to run 3d drawings in AutoCAD 2011.
The current system I am using is:
Dell Inc. OptiPlex 745
3.40 gigahertz Intel Pentium D
16 kilobyte primary memory cache
2048 kilobyte secondary memory cache
3 GB RAM
256MB ATI Radeon X1300PRO [Display adapter]
256MB ATI Radeon X1300PRO Secondary [Display adapter]
AutoCAD 2011 on Windows XP
Cadalyst Total Index of 103
AutoCAD runs extremely slow and crashes while working on 3D drawings. I mainly work on 3D drawings of electrical enclosures in the 2D wireframe view I don't need to do any rendering or anything like that.
Any suggestions for hardware upgrade or recommended PC requirements to run 3D CAD efficiently?
Raf
Solved by OMCUSNR. Go to Solution.
Do you have a budget in mind?
I put the system in my sig together for just under $1400 USD by ordering parts from Newegg.com and assembling them myself (add a DVD burner & a card reader to what's listed - &, my degree is in studio art, not engineering, so it's not hard to put stuff together if you can use a screwdriver, and are patient.). It would handle straight ACAD w/ 3d wireframe pretty well.
If you're looking to save a bit, look for an I-3 system, but add a decent video card.
Most would advise a system with Win 7 64 & 8 gig of ram as a minimum. Many are going with a SSD for faster program loading, but I'd rather spend the money on a faster HD.
HTH,
Reid
What do you guys think of this as an upgrade:
Dell Precision 690 Tower
With option for swapping th FX4600 for a FX 3450 (not sure which card would be better?)
Price $550 CAN
It has cheap going for it, but it's older tecnology - basically one step above what you have & one step behind what you need.
You don't need the dual xeon processors for acad - acad uses one core only.
The 8 gig of ram is good
250 GB SATA HD - is a bit light. I'd go with a Western Digital Caviar drive with at least 500 gig of storage, spining at 7,500
The video card is good, but won't do a lot of rendering.
The 750 Watt ps is overkill for that system.
Vista is a dead OS - Go with Win 7 64 bit Pro (no home editions or 32 bit)
We are most likely going to go with the following system from newegg
quad i7 3.4GHz
2 x 4gb DDR3 SDRam
max smilodom ATX case w/ 500W power
GeForce GTX 560 1gb Gddr5
Western Digital Caviar 2TB HD
Win 7 64bit Pro
All for $1300 can
Thanks for all the feedback!
I have 2 machines with the dual xeon 5150s. I am diappointed. I agree with the other posts. The Optiplex and Precision lines have the same failure rate as consumer grade machines. Look into a Dell Studio or Alienware, or as previously mentioned, configure and build one yourself. Newegg can help make sure everything is compatible.
There is an Acer Predator on Amazon for under $1,000, but it is Win 7 Home Premium.
Win 7 x64 Pro
Intel Core i5 or i7
Minimum 8 GB triple channel RAM (make sure chip set supports it)
Consumer-grade graphics card (FireGL and Quadro are overpriced) nVidia GTX 560 or better
Solid-State Hard Drive for OS and apps, and second standard 7,200 rpm drive for file storage.
I think that RAM is the most important. Always leave room for more.
