Using a Core i7 means you are getting a system that uses triple channel
memory, not dual channel. If you increase the ram beyond 6 GB, you should
go to 12 GB so that you buy three modules of 4 GB or six modules of 2 GB. I
like to leave open slots for later when I need to expand my memory, so
getting the larger modules now may be the way to go. I believe the
motherboard will have six slots, but best check it out.
Going with a newer version of Inventor on Windows 7, I don't think there are
any advantages to an OpenGL card, but a lot more cost.
One downside to Windows 7 is that while Inventor is on the list of tested
and confirmed Autodesk software, Vault is not. That does not mean it won't
work, but just not tested at this point.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14053691&linkID=9240697
Brad
C3D 2010 on Vista Business 64 SP 2
LT 2010 on XP Pro SP 3
"Hal Gwin" wrote in message
news:6294917@discussion.autodesk.com...
For the most part the system you are looking at should be adequate for
what you want to do. I would probably take the RAM up to 8GB if you are
importing STEP or IGES files that are as large as you indicate (no such
thing as too much RAM).
I don't have any experience with the ATI cards other than they have
always had a bad reputation with Inventor users in the past. Now that
Inventor is using Direct3D they may be OK, however I don't see any
driver recommendations for the card you selected on the Autodesk site.
I prefer the Quadro FX cards, but would try one of the nVidia GeForce
9800 or 8800 series cards if I couldn't get a Quadro.
Inventor won't care if the CAD system you are importing STEP or IGES
files from was using OpenGL or not, so you really don't have to worry
about that. Having enough RAM to handle all the data will be more
important, so an x64 OS and 8GB or more of RAM will be a necessity. I
have the only seat of Vista x64 in a company of 100+ and have had no
problems getting everything to play nice.
swebster@pekoprecision.com wrote:
> I know there are many posts on Inventor hardware requirements and I think
> I have a solid build - I just want to try to make sure I haven't missed
> anything. My hardware background is primarily gaming and home PCs.
> Here is what I am about to request from IT. We have a small engineering
> group of 5 people that runs all the standard Office apps, Inventor 2009.
> We work with assemblies of up to generally less than 200 components,
> sometimes up to 4000-5000 components. We're currently running XP 32 bit
> but I am pushing hard for Win 7 64bit.
> Generally the larger assemblies involve importing a assembly from another
> CAD platform like Unigraphics or NX or ProE or Catia. This takes a long
> time or is even impossible on our current P4 systems. One thing I couldn't
> determine is the need for OpenGL support when opening and translating
> files native to a CAD platform that does require OpenGL. Will the HD4870
> be sufficient for this type of activity?
> Here's my Hardware list:
> SAMSUNG CD/DVD Burner Black SATA Model SH-S223C $25.99
> 1 Antec Sonata III 500 Black ATX Mid Tower Computer Case EarthWatts 500W
> Power Supply $109.99
> 3 Western Digital Caviar Blue WD800AAJS 80GB 7200 RPM SATA 3.0Gb/s 3.5"
> Internal Hard Drive $34.99 each (setup in RAID 0)
> 1 XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16
> Video $154.99
> 1 Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor
> $288.99
> 1 Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
> $139.99
> 1 Kingston HyperX 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
> 1 GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard Combo
> Price $368.98
> Total: $1,193.90
> Looking to get 4-5 years out of these. See anything wrong? Possible
> problems or weaknesses? Overkill or deficiencies anywhere?
Hal Gwin
Mechanical Designer
Caliper LifeSciences
R2009 Pro SP1 D3D10
Vista x64 SP1
Dell Precision T5400
3.00 GHz Xeon 8 GB RAM
Quadro FX 1700
nVidia 7.15.11.8246 w/registry update
Dell UltraSharp 24" Widescreen LCD
