Hardware (Read Only)
New Machine Query
2 REPLIES 2
trevor.siu
537 Views, 2 Replies
New Machine Query
Hey Guys,
I am in the middle of spec'ing out a new PC for use with Revit, Inventor, Autocad, and NX.  I was talking to someone that said that Xeon processors are better for this kind of modelling over i7.  Anyone have any experience/advice?
Cheers
Trevor
2 REPLIES 2
dgorsman
in reply to: trevor.siu
Doubtful under most budgets.  Search the threads here for some soapbox-speeches on Xeons and "workstations".
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
I'll spare you the rant on what I've been through in trying to obtain a great CAD machine for the type of programs you cite in your question - in a nut shell (my experience) the single biggest advantage to a XEON over the newer i5/i7 processors is the memory issue. From Intel "The Intel® Core™ i7 desktop processors and desktop boards typically do not support ECC memory. ECC memory is usually used on servers and workstations, rather than on desktop platforms."  That said, there can be a motherboard here and there that claims to support it and I think there are actually 3 of the higher priced i7s that support it.
If you do a price compare you will find that the new E3 Xeons are a good buy compared to the i7's -  i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad is about $300 and you can spend almost anything you want on memory - but it appears to me that the single core number is what you need to pay attention to, not so much how many cores. - with all but the really complex models, hyperthreading take off a good amount of the load and it works with a good graphics card.
The Xeon E3-1270 Sandy Bridge 3.4GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 80W Quad-Core is about the same price - but - it fully supports ECC and from experience, this is a big difference in the amount of stability you get in the system. So I would always opt for stability - but both will perform almost identically in terms of actual system speed - assuming all things are equal. And ECC memory direct from say Crucial is a good buy - cheaper than the likes of Newegg, etc.
