Hardware (Read Only)
My hardware acceleration wont work
2 REPLIES 2
1040 Views, 2 Replies
I have a 1gb nvidia 310m video card and when i checked the test tool for my GPU it says GPU ON but my autocad tune log says i dont have a driver... this is what my tune log says:
Performance Tuner Results LogVersion: 18.2.0.0Date of Last Tune: 7/5/2011
Machine Configuration
Processor Speed  : 2.5 GHz
RAM              : 3885 MB
3D Device
Manufacturer     : N/A
Chip set         : N/A
Memory           : N/A MB
Driver           : N/A
Hardware acceleration is not available because not enough video memory is available.
Current application driver:    Software
Current Effect Status:
Enhanced 3D Performance:   Not recommended and off
Smooth display:            Not available
Gooch shader:              Software emulation in use
Per-pixel lighting:        Not available
Full-shadow display:       Not available
Texture compression:       Not available
Advanced material effects: Not available
Available application drivers and effect support:
Software driverEffect support:
  Enhanced 3D Performance:   Not applicable
  Smooth display:            Not applicable
  Gooch shader:              Software emulation only
  Per-pixel lighting:        Not applicable
  Full-shadow display:       Not applicable
  Texture compression:       Not applicable
  Advanced material effects: Not applicable
Autodesk driver:  Not Certified
Effect support:
  Enhanced 3D Performance:   Available
Anyone know how to resolve this problem??? Help would be pretty much appreciated
2 REPLIES 2
pendean
http://www.autodesk.com/autocad-graphicscard to find the Autodesk driver for that card, if one exists.
TravisNave
Your WHQL Certified driver for Windows 7 64-bit on this device is:
http://www.nvidia.com/object/notebook-win7-winvista-64bit-275.33-whql-driver.html
Though the Autodesk xml files may not be updated to show certified, the WHQL driver is accepted by Autodesk.  Thus, you should be able to override any automatic settings and manually enable the options that you desire.
If you need a different driver for a different OS, please download the appropriate WHQL driver from nVidia.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Autodesk Forums:
