First things first
1) How much memory do you have now or will have after upgrading. If less
than 4gb, I wouldn't waste my time with an upgrade, since you gain too
little unless you get 64 bit, and the only advantages to 64 bit revolve
around extra memory. Some things got better in 7, some things got worse,
but the net result is somewhat improved. Weighing that against the
effort necessary for the upgrade and I wouldn't do it unless I went from
32 bit to 64 bit.
2) Can you get all the drivers you need for your hardware? Especially
look at your plotter since that, because of price, may be the oldest
thing you still need. If there is a Vista driver then that will work for
7. HDI drivers work but not well.
Paul wrote:
> I have an Dell M6300 running Win XP Pro. looking for opinions on is it worth
> the time and effort to wipe and reinstall all my programs?
> The Core 2 Duo T7700 will run 64bit correct?
> Programs I use
> - Inventor 2010
> - Photoshop CS2
> - PCDMIS 4.3 connected to a Romer Infinate 2.0
> - All the usual office/email stuff.
