Hardware (Read Only)
I need advice on the laptop i want to purchase
4 REPLIES 4
537 Views, 4 Replies
I am about to get this laptop (http://h40059.www4.hp.com/uk/homelaptops/pdf/dv6-3180ea_ds_ene.pdf), and I use AutoCAD, photoshop cs5, Autodesk Revit, and 3ds Max. Do you think this laptop is a good
chioce? or do you have any advice? Dont really know much about processors.
Thank you in advance.
4 REPLIES 4
pendean
That's a small screen for your 4 listed programs: is this a casual-user scenario, or a casual-use laptop?
What is your budget $$?
in reply to: pendean
My budget is £700/$1000. Well its my personal laptop, i will also use it for other things but because of the field i am in, when I am at home,
and not in the office,i will have to use those software on my laptop...What do you think?
pendean
OK, so this is for casual/oocasional use of those four applications: you'll hate the small screen (and low-end vertically) and most likely do anything you can to not do real work on it, but hopefully that HDMI port will let you connect to something more decent and still higher res than that VGA port.
The RAM should be in the 6-8Gig area (especially since the video card seems capable of robbing 2.5gig of it for itself alone) HD speed is decent (7200rpm), video card is designed for this laptop's target audience (entertainment) and is not great for the two+ apps you have that prefer higher end graphics. It's decent for your price range, enjoy it's non-work perks and feature set.
@ $1000 USD, you're running the ragged edge for the acad products.  The processor is a tad bit slow, and I've never yet come close to needing a terabyte HD.  I concur with pendean that the screen is marginal at best.  You really do NEED a 17" screen as a minimum to use acad products.  The menus take up too much space, and you'll be constantly panning & zooming to do any drawing.
Realistically you need to up your budget to about $1400 usd to get a portable that will handle the acad products you've listed, and $1800 would be better.
Reid
