Hardware (Read Only)
Hp Design Jet 750 C +
5 REPLIES 5
1046 Views, 5 Replies
Our company just purchased our first plotter an HP DesignJet 750C Plus.  I cant seem to get it to work.  I am running Windows 7 and cannot find a driver for it.   Can anyone help me out.  I tried the 1050C Driver for windows 7, but that doesnt seem to be working either.  Whenever I send something it says error in the printer que.  Thanks
5 REPLIES 5
pendean
Like most current Windows versions...
Win7's Control Panel>Hardware>Devices and Printers>Add a Printer> select the type, give Win7 an ideas where to find it (port, or IP address)> and if needed select the UPDATE button for Win7 to tap Microsoft for a full list and you will eventually find the HP list populated with the driver you need.
Or in AutoCAD, most versions shipped since the 750 was retired, PLOTTERMANAGER command>Add-A-Plotter>HP>there you will find multiple choices for the 750 as well.
What version of Windows 7? 64 bit or 32 bit? If 64 bit search HP for XP64 driver. It will work
32bit
AllenJessup
Have you tried the XP Drivers?
Allen
Allen Jessup
CAD Manager - Designer
What you need to do is to look up the manual to set the 750c plus ip address manually then use the drivers for the 430c plus (e/ao) to install it that worked with us
