Hardware (Read Only)
HMARCHITEKTEN
613 Views, 2 Replies
graphics card
i have a problem updating my graphics card. i find an update available using '3dconfig' but then i cant install it for missing the permission to write the data. i have no idea how i can solve this issue. i use a nvidia quadro 2000 graphics card.
thx for any help
2 REPLIES 2
entropist
in reply to: HMARCHITEKTEN
Most likely you require admin rights to update the driver. Check with your network administrator, or change your login credentials yourself.
TravisNave
Make sure you are downloading a WHQL certified driver direct from nVidia.com.  Here is the Windows 7 driver for your card.  If you have Windows XP, just change accordingly.
http://www.nvidia.com/object/quadro-tesla-win7-winvista-64bit-297.03-whql-driver.html
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
