I agree with Laurie.
For the processor: Intel Core i7, Core i5, or Core 2 Quad. A Core 2 Duo
will work, but the upgrade charge for quad processors is not that much to go
to Core 2 Quad with similar speeds. Intel is kicking AMD's butt right now,
so go Intel.
RAM: 2 GB bare bones minimum for LT, 3 GB for 2D work on full AutoCAD, 4 GB
for most applications, 8 -12 GB for C3D and other intense vertical packages.
Video card: Biggest fastest Nvidia Geforce or ATI Radeon you can afford.
Don't waste money on OpenGL cards unless you have a program that requires
it. AutoCAD and most vertical products don't, but some other program may.
I run C3D and my budget was tight, so I went with a Geforce GTS 250 with 1
GB of video ram. Works ok, but not as fast with large images (200 MB) as I
would like. I am not sure if the bottle neck for the images is the video
processor, video ram, main processor, regular ram, or hard drive at this
point. I have ordered more regular RAM to go from 4 GB to 8 GB.
Brad
C3D 2010 on Vista Business 64 SP 2
3.0 GHz Core 2 Quad Q9650
4 GB going to 8 GB RAM
Geforce GTS 250
250 GB hard drive for OS & software
1 TB network drive, RAID 10
"Laurie" wrote in message
news:6310321@discussion.autodesk.com...
Hi Doctor Carlo,
It's the nature of the beast that the variables associated with usage
are so extreme that it is not really possible to say much more than
"more and faster is better"
Although I think he lives in fantasy land, recently there was a user in
the newsgroups saying that 1Mb RAM, Vista 32bit is fast adequate for
everything he does in AutoCAD.
I think there is little doubt that Civil 3D is the most resource hungry
of the Autodesk programs and the range of file sizes reported in Civil
3D newsgroups vary by factors of more than 10, so what is normal OK for
one user will be inadequate for another.
If I was buying/building a new computer I'd say:
Win 7 64 bit - don't even think of anything else.
Unless you are planning to work in small files (Sub 1Mb) 8Gb RAM(some
RAM comes in 3Gb modules, so 9Gb or 12Gb may be appropriate)
Enough 10,000RPM hard disks that RAID 5 is workable for the data drives
O/S and software on separate drive so that imaging is easy.
The two biggest monitors which fit on your desk
Upper mid range Intel processor as the speed increments for the dearest
ones don't warrant the cost.
I know next to nothing about graphics cards, but there is plenty of
information around and what's accurate today will be out of date next week.
Laurie Comerford
DoctorCarlo wrote:
> Does a Qualified Hardware Chart exist for AutoCAD? I have found one for
> four of the twenty-seven AutoDesk programs. They were clear as a bell.
> Five others featured minimum system requirements for only the processor.
> The remaining either had "404" links or no links at all.
> Am I asking too much for a Qualified Hardware Chart for AutoCAD?
> I am building a custom system for AutoCAD and I would like to refer to
> some clear-cut specifications.
