Hardware (Read Only)
Canon imagePROGRAF iPF710
3 REPLIES 3
565 Views, 3 Replies
Group,
We have just received the Canon imagePROGRAF iPF710 plotter.
I thought to ask how do you rated, experience someone might have and issues
to be aware of if any?/ drivers etc.
Using Acad 08' on XP pro, possibly upgrade to...2010 or 2011, engineering/
architectural drawings, mainly B/W.
Thanks for any input
RC
3 REPLIES 3
RC wrote:
> Group,
> Regards,
> RC
I use a ipf700 and it is a good plotter but isn't used very often and
tends to need to have the maintenance cartridges replaced about every 6
months and the printheads tend to dry out causing it to make plots with
streaks...otherwise no real problems with it...
Thank you for your comment
RC
"K" wrote in message
news:6346302@discussion.autodesk.com...
RC wrote:
> Group,
> issues
> Regards,
> RC
dlacomb
We have both the 700 and 710 Canons. I personally like them better than HPs. As someone else said, if you don't use them enough, they tend to gum up - this has been our issue as well. We typically run a plot of the AutoCAD color chart at 11x17 size to each one each week to work out the jets. Very dependable units - minimum service.
