The 4870 x2 is crossfire in 1 slot. The x2 means 2 gpu's working
together on 1 board. I know nothing about the 2 boards otherwise, but I
suspect that the second gpu will never be used by acad.
sw3dp wrote:
> I learned more in 2 min than 4 hours hardware research, thank god for forums(or was that the Romans). I used to use an old Dell laptop as my main workhorse; it had a 1.3 P2, 1GB ram, on board ATI graphics, XP32 chop chop, and AutoCAD 2004-2007 worked flawlessly (pushing the envelope back then) for complex 3D parts rendering for machine prototyping until I reached the 8MB file size, ah the days of off the shelf hardware. When 2008 hit, the laptop was dead and I had to move on, switched to affordable duel core, vista 32, 128MB DDR2 Nvidia 7000something, 4GB DDR2 RAM and functionally I took a 80% paycut because it was like working underwater, in molasses, and I'm sure I aged 10 years and put on 20lbs snacking while waiting for 3D Orbit to rotate the part. Autodesk resellers used to give me that deer in the headlights look when I would ask for the "real" hardware requirements for 3D rendering, of course I never had the $6k budget for a pc in 2006, still don't.
> Now it looks like there may be hope once again in building my new work station for under $3k. Thanks for warning me off of SLI I almost made a $700 blunder. I understand the difference between ATI and Nvida is mostly architectural and though the stat sheets for a GTX look poor compared to Radeon HD (as in stream processors 200 vs 800(2)) in performance testing the benchmarks don't show dramatic difference,s at least when you consider one is half the price of the other. At this point however I will defer to those with actual acad experience.
> To my question: please advise on which card goes best with 2010 and system...Vista or 7 64bit , Intel Core 2 Quad, 8-12GB DDR2 800 RAM,
> Radeon HD 4870 X2 2GB 512-bit GDDR5 $300,
> or GeForce GTX 285 1GB 512-bit DDR3 $300
> Edited by: sw3dp on Jul 16, 2009 1:36 PM
