Hardware (Read Only)
Autodesk performance drivers
2 REPLIES 2
MatthewFulton2217
478 Views, 2 Replies
Hi Everyone,
I'm just wondering if there is any news on what autodesk will provide performance drivers for in the next iteration and years to come? Basically something that will have a performance driver in 3 years time is desired. We are looking at the Nvida quadro 2000 and 4000 currently.
matt
2 REPLIES 2
Probably better off in the hardware area.  For what its worth, companies will rarely discuss next years offerings now, let alone three years down the road.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
I've never been a big fan of the performance drivers in the past.  As long as you are up-to-date on a recommended workstation class video card running a WHQL certified driver, you will be fine.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
