Hardware (Read Only)
3D/Reality Capture Hardware requirements?
2 REPLIES 2
Light_Guy
625 Views, 2 Replies
So, we are entering the world of reality capture here. Point Clouds and laser scanners! WOO HOO!! Can anyone recommend desktop/laptop hardware minimums? I was at a panel discussion at AU2012 and they mentioned the HP Z800 and the others kind of nodded. I also read somewhere that a SDD hard drive is better than a SATA for 3D work. I am trying to get my IT folks looking at a proper standard for 3D work but need some good real world data to support my suggestions. Any help is ALWAYS appreciated!
Paul Hamor
"Always good ships!"
2 REPLIES 2
dgorsman
in reply to: Light_Guy
WOO HOO and point clouds do NOT go together.  Useful, yes, but be prepared for hair loss.  Remember its reality, whereas the engineers/clients are usually looking for rationalized or optimized design values - e.g. angles at a perfect 90 degrees.
SSD vs. SATA 6Gb/s won't matter much if you are sharing data, likely the data will be served rather than local.  There are a few minor advantages to an SSD in general performance and cost but nothing specifically related to 3D work.
Point clouds are *very* data intensive, so the most RAM you can stuff into the motherboard is your main goal, and usually acheivable in cost if you don't go for the uber-ultra-game-spec or ECC stuff.  Normally I'd put processor speed first but in this specific case I'd make it a very close second, as point cloud management software will usually do a good job of managing those points for you.
Z800's are OK, although a bit of overkill for most work, expecially if you need more than one or two.  If you already have a purchase contract with HP, the benefits will probably outweigh the extra costs involved.  If this is a one-off, consider a custom build.  This is exactly the situation where custom building is an advantage over mass-sourcing.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Light_Guy
We have the HP contract and we need about 10 machines to start so I guess we might lean the 800 way. Thanks for the info!
Paul Hamor
