Insight Energy Forum
Welcome to Autodesk’s Insight Energy Forums. Share your knowledge, ask questions, and explore popular Insight Energy topics.
Run Status:In Run Que GBS
14 REPLIES 14
Message 1 of 15
dave_20005
745 Views, 14 Replies
I have a problem where when i run an Energy Simulation the simulation never actually begins. When i log onto the GBS it shows the run status as in run que (0%)
This status never changes until the run fails. Does anyone else have this problem?
14 REPLIES 14
Message 2 of 15
fmin0r
in reply to: dave_20005
I have the same issue...
Message 3 of 15
mstein7484
in reply to: fmin0r
Are you still experiencing this problem? If yes, is it happening with all of your models? Is it happening consistently, or intermittently? What is the error message you see when you mouse over the failure notice in GBS?
Marjorie Stein
QA Analyst
Generative Design Group
Autodesk, Inc.
insight.support@autodesk.com
Message 4 of 15
fmin0r
in reply to: mstein7484
Now it's working. I hope it lasts because it was very frustrating to bump into this right on the day I had to use Vasari to teach a class...
Francisco
Message 5 of 15
mstein7484
in reply to: fmin0r
We're very sorry that you experienced a disruption in the service.
Marjorie Stein
QA Analyst
Building Performance Analysis
MAIN +1 415 679 7846
DIRECT +1 415-507-4757
Autodesk, Inc.
1031 North McDowell Blvd
Petaluma, CA 94954-1173
www.autodesk.com<>
[Description: Description: Description: Description: Email_Signature_Logobar]
Marjorie Stein
QA Analyst
Autodesk, Inc.
Message 6 of 15
Jordry123
I am having the same problem as well. Is it just that the cloud is overwelmed?
Message 7 of 15
mstein7484
in reply to: Jordry123
What is the error message you are getting? That will help us track down the issue.
Marjorie Stein
QA Analyst
Autodesk, Inc.
Message 8 of 15
Jordry123
It showed the run status as in run que (0%). The run finally completed but it took several hours. If this is normal, let me know.
Thanks.
Message 9 of 15
mstein7484
That is not a typical processing time. What is the size of your Revit model? (how many kilobytes).
Marjorie Stein
QA Analyst
Autodesk, Inc.
Message 10 of 15
Jordry123
85,956 KB
Ryan Jordan, AIA, LEED(r) AP BD + C
GWWO, Inc./Architects
800 Wyman Park Drive
Suite 300
Baltimore, MD 21211
T: 410.332.1009
F: 410.332.0038
[cid:image011.jpg@01CE9DBD.CE417860][cid:image012.jpg@01CE9DBD.CE417860] [cid:image013.jpg@01CE9DBD.CE417860]
Before you print.... Remember the trees!
Message 11 of 15
mstein7484
Thank you for the information. I will check with the development regarding an expected processing time for a model of that size. Another factor that impacts the processing time is the traffic on our servers at the time you initiate the energy analysis.
Marjorie Stein
QA Analyst
Autodesk, Inc.
Message 12 of 15
dirkclyburn
hi on que for 1hr now
1732kb
Message 13 of 15
mar.prete
in reply to: dirkclyburn
On que for several hours today. The model is a very simple mass cube.
Message 14 of 15
krishnan.gowri
in reply to: mar.prete
Currently there are no problems observed with the simulation web service.  Please try resubmitting the model.  If you still encounter such a long delay, send us your Revit model at krishnan.gowri@autodesk.com.
Krishnan Gowri, Ph.D. FASHRAE, LEED AP
Principal Engineer
Message 15 of 15
ekkywona
in reply to: krishnan.gowri
Hi, i have same problems, "Run status: In run queu", my file is 95.788 kb. is it affect the analysis process?
