Insight Energy Forum
Welcome to Autodesk’s Insight Energy Forums. Share your knowledge, ask questions, and explore popular Insight Energy topics.
Run Failed
1 REPLY 1
SdavidJ
504 Views, 1 Reply
Run Failed
Hi everyone I'm a student and I have to run a building through GBS, but everytime I try to do this, I get the warning "run failed". Can you please help me with this problem? I have linked a picture of the whole detailed warning below. Thank you.warning.png
1 REPLY 1
mstein7484
in reply to: SdavidJ
The error message indicates that you are using a window construction that is incompatible with how DOE-2.2 (the simulation engine used by GBS) simulates windows. Is this a window construction you created yourself? Or one from the Revit library?
Try to simulate the model again without specifying the window (GBS will automatically apply properties to your windows, based upon ASHRAE baseline requirements for your project location).
Marjorie Stein
QA Analyst
Generative Design Group
Autodesk, Inc.
insight.support@autodesk.com
