Green Building Studio
New Member
0 Kudos
Post 1 of 3
Revit to GBXML
1371 Views, 2 Replies
06-22-2012 07:11 AM
Hi all,
The revit geometry is exported as gbxml format and in the export gbXML –settings, all the external walls are showing as internal walls. This is causing the external walls not to show up in the energy modeling software later when imported. Is there a easier way to fix this issue ? Any insight in this area is much appreciated.
Harshana
Employee
4 Kudos
Post 2 of 3
Re: Revit to GBXML
06-24-2012 08:58 PM in reply to: hthimmanna
This may be a result of that the Function parameter on the wall type is set to “Interior”. Can you please check that?
For more info please see: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171...
Anna Oscarson
QA Analyst
Building Design and Collaboration, IPG
New Member
0 Kudos
Post 3 of 3
Re: Revit to GBXML
07-10-2012 11:51 AM in reply to: AnnaOscarson
Thanks Anna.. That worked
Harshana
