When running my GBxml file in the web based edition, i don't get any charts running. When checking my error, i get an error basically saying that i need to tone down on my external shading... but the thing is i have barely any at the moment! Does anyone know what could possibily be wrong? Thanks.
Thanks for the reply.
It's a hospital design, so i have my designated rooms inside which are all bound... but then i have the surroundings of the hospital also designed, so the site area, paths, road, car parking etc, are all designed as floors. Is this what you mean?? Is Would hiding these elements or deleting them from my model and only having the building itself help in analyse? Many thanks.
Yes, those external elements are being read by DOE-2 as “shades”, and unfortunately there is a limit in DOE-2 for the number of shading surfaces in can handle. You may have to delete/hide these elements for the energy analysis to run successfully.
I took your advice, and my external shading number ha been reduced. However i'm still over the DOE limit of 1024 (im on 1271 at the moment). I've literally deleted everything that isnt a room bounding wall/floor, and left in elements such as ceilings and windows, etc. Do you have any other tips? My site is only small... so i am a bit perplexed as to why this is still happening.
Regards.
It sounds like there are problems with the model formation. If you have Revit 2014, within the program folder look for GbXML2Dwfx.exe. This will allow you to view your model in Autodesk Design Review (free tool). Just drag an xml on to the GbXML2Dwfx.exe and it’ll create a dwfx next to xml file. You can view all of the surface types of your model and identify ones that are still being categorized as shade surfaces.
