Insight Energy Forum
Welcome to Autodeskā€™s Insight Energy Forums. Share your knowledge, ask questions, and explore popular Insight Energy topics.
Showing results forĀ
Did you mean:Ā
inp file to equest
4 REPLIES 4
mohamed.hkhater
948 Views, 4 Replies
inp file to equest
hi
when i use the inp file in equest i think its very diffcult to create new space in equest from inp file
is there a way to export the spaces from gbs to equest or any easy way in equest to  creat spacefic space in equest?
thanks
4 REPLIES 4
The best workflow is to create all of the spaces in your authoring application, such as Revit, submit your model to GBS, and download the .inp file from the GBS website to use in eQUEST.
Marjorie Stein
QA Analyst
Generative Design Group
insight.support@autodesk.com
Hi Mohamed,
Please see Placing Spaces page in Revit help to learn how to place spaces. In order to set space as export category, follow the steps in Exporting Design to gbXML page. In this page use the second part to set spaces as export category.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Mohammad Asl
High Performance Building Design Researcher
Insight360.support@autodesk.com
when i use  the exported gbxml file in gbs and export inp file for equest ,equest identify zones not spaces
and when run energy simulation mode in revit in gbs and export inp file for equest no spaces and zones identify in equest
If I'm understanding you correctly, what you are seeing in eQUEST is simply the naming convention sometimes applied to the names of Spaces and the names of Zones by GBS. If you look at the eQUEST interface you will see the field is "Space Name" in the Building Shell components; and "Thermal Zone Name" in the eQUEST Air-Side HVAC components. The spaces and zones are present in the eQUEST model.
I'm not clear on what you mean: "when run energy simulation mode in revit in gbs and export inp file for equest no spaces and zones identify in equest." The energy simulation will not succeed without spaces and zones in eQUEST. Could you send me the .inp file for this case?
Marjorie Stein
QA Analyst
