Green Building Studio
Active Member
tzigo
Message 1 of 3 (1,719 Views)
Failed Run
1719 Views, 2 Replies
03-18-2010 08:13 AM
This was my second attempt to submit this warehouse model, and as I did not find the link for bug report on GBS website I am including this error message for further help.
: Issue: An error has occurred related to the DOE-2 simulation. It is below and may be of assistance in determining the issue with your building model. If it is unclear what the issue is, please submit the issue at the link below and include the gbXML file used for this run.
*15048* EQUIPMENT-W/AREA = ( NaN )
*ERROR******************************* === ****************************************************ERROR IN NUMERIC INPUT VALUE
*15049* NUMBER-OF-PEOPLE = 0.0
Employee
mstein7484
Message 2 of 3 (1,719 Views)
Re: Failed Run
04-07-2010 12:54 PM in reply to: tzigo
Was this model created in Revit MEP? If so, it looks like the problem was with the assignment of equipment watts. Go back to your Revit model and put in a numeric value for equipment loads.
If not, please contact support through the Subscription Center (www.autodesk.com/subscription) and also send them the gbXML file to look at.
Best Regards,
Marjorie Stein
Autodesk Green Building Studio
Marjorie Stein
QA Analyst
bpa.team@autodesk.com
Member
davidmorg
Message 3 of 3 (1,322 Views)
Re: Failed Run
09-07-2011 03:56 PM in reply to: mstein7484
Hi Marjorie,
I also have a failed run. Do you know what the problem is with mine?
Issue: An error has occurred related to the DOE-2 simulation. It is below and may be of assistance in determining the issue with your building model. If it is unclear what the issue is, please submit the issue at the link below and include the gbXML file used for this run. <br/>     *4765 *    ..<br/>*ERROR****************************************************************************************Two VERTICES are identical  <br/>     *4766 *  <br/>     *8259 *    ..<br/>*ERROR****************************************************************************************<br/>*ERROR*****AREA in S~zone-10 has Expression Evaluation Error: Polygon contains<br/>
