Green Building Studio
New Member
david.salamon
Message 1 of 2 (1,273 Views)
Accurate analysis of stud walls with cavity insulation
1273 Views, 1 Replies
02-18-2014 06:32 PM
Does Revit / GBS accurately calculate R-values for wall assemblies with insulation between studs?  It doesn't seem like it can without a complex work around involving manually calculating the different material properties and then creating an average to account for differences in thermal bridging depending on material and spacing.  I've searched quite a bit online and haven't found any satisfactory answers.
dcs
Employee
mstein7484
Message 2 of 2 (1,258 Views)
Re: Accurate analysis of stud walls with cavity insulation
02-19-2014 09:05 AM in reply to: david.salamon
Yes, the R-value for wall assemblies with studs is taken into account in the GBS constructions by de-rating the r-value of the construction -- including differences between wood studs and metal studs.
Marjorie Stein
QA Analyst
Autodesk, Inc.
bpa.team@autodesk.com
Post to the Community
New Post
