Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Update Model From Revit
3 REPLIES 3
liorman
417 Views, 3 Replies
Hi there,
Okay, I have worked on my scene, set shots, costomized background but now I had to change my Revit model. Can I update my showcase model geomatry directly from Revit?
Thanks in advance
3 REPLIES 3
liorman
in reply to: liorman
Okay, I have saved my Revit model as an FBX file. Imported file, then in the add in manager erased the old file. I don't know if there is a smoother way to do it but it works.
You can reload your Revit model from the Import Status Window.
Press i on your keyboard, select the FBX and select the option: reload.
Have a look at this video from Jonathan Landeros to help understand the process:
http://www.youtube.com/watch?v=leWnF9xm6sE&feature=share&list=PLD6D46E8F19539A17
Marion
liorman
Marion,
Thank you for the reply. I am assuming you mean replace and not reload (at least in my showcasr relode is not an option while open the Import Status Window. I have remove, replace and import files. I am using the replace option but it is taking very long 😛
