Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Ugly faces in Showcase from FBX exported from Max 2014
4 REPLIES 4
787 Views, 4 Replies
As you can see in the attached picture, I don't get plain faces when I import a FBX from MAX.
Any ideas what I have done wrong?
Roland
4 REPLIES 4
MarionLandry
You need to use FBX 2013 version when exporting from Max 2014. Watch this video:
At 2m56, I am getting the same result as you are getting.. Watch the complete video to understand how to export and FBX 2013.
http://youtu.be/Gv5LH6No31I
Let me know if that helps
Marion
Marion Landry
Technical Marketing Manager
3ds Max Design + Showcase
Twitter @MarionLandry
YouTube Channel @LandryMarion
https://www.facebook.com/Autodesk3dsMax
https://www.facebook.com/Autodesk.Showcase
http://www.linkedin.com/pub/marion-landry/4/a78/258
This was the problem, thank you. FBX2013 fixed it.
cikho
in reply to: MarionLandry
does this also affect baked shadows? because i'm getting strange artifact on that, both in SC 2013 and 2014
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
MarionLandry
in reply to: cikho
Do you mean baked shadows that you did in 3ds Max Design? It should not.. but then again.. without visual, it's hard to know what is going on.
Marion
