Hallo!
Please help me to create an animation screw-nuts ...
I Can`t combine the two moving:
1. move nut along bolt axis and 2. nut rotation around bolt axis simultaneously
Solved by oleg_inv. Go to Solution.
Solved by MarionLandry. Go to Solution.
Solved by cikho. Go to Solution.
go to organizer.
select the bolt
create a group containing the bolt
now create another group containing the group created before.
animate the first group with the rotation
and the second group with the sliding movement..
i did not test this, but this is how i animate folding doors and it works
here is a quick example
check the organizer for the group reference
Thanks to you Cikho, I was able to record a video showing the steps.
Hope this helps.
I wish I had a better model for it.. oh well..
Marion
