Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Problems loading part
14 REPLIES 14
Message 1 of 15
912 Views, 14 Replies
Dear,
I have a problem with Autodesk Showcase 2015. If I open it and want to render the car from autodesk self, it works fine. When I try to open an own file, it crashes immediately. I send the error file a couple times but never had an answer.
I use windows 8.1.
Autodesk Inventor 2015 works fine and my pc is normaly good enough for both programs.
Please, can anyone help me?
Kind regards,
Kyani
14 REPLIES 14
Message 2 of 15
Christian_Garimberti
You must provide more infos....
Pc specs, error message...
You can also attach an example of your model
you can also check showcase log files. maybe the error is explained there...
in windows explorer type %TEMP% and searc for files named Showcase 2015Log
open the files with notepad.
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 3 of 15
in reply to: Christian_Garimberti
Sorry,
Here more information. I have removed and reinstalled inventor and showcase. This gives still the same problem.
The file isn't really necessary because I can't open any own file.
My computer specifications:
- Processor: Intel (R) Core (TM) i7-3632QM CPU @ 2.20GHz
- RAM: 8.00 GB
- System: 64-bits x64-processor
The error:
Errors
Is this enough information?
Thanks for your help!
Message 4 of 15
cikho
so this happens when you open a file saved from you or when you try to import a source file from, i think, inventor?
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
Message 5 of 15
in reply to: cikho
Yes. Sometimes I can open a project file but sometimes not. It crashes always.
Message 6 of 15
cikho
another small question, i see you're running it on a laptop (the processor is an M series): does it have an nvidia gaming graphics (geforce)? if you also have the intel embed graphic card, try running showcase with that card
Message 7 of 15
just to have more infos.
in windows explorer type %TEMP% and searc for files named Showcase 2015Log and attach the files in your reply.
thanks.
Message 8 of 15
in reply to: cikho
Normally Showcase is running on my gaming graphic cards (it is a NVIDIA GeForce GT 650 M)
Message 9 of 15
I don't understand what you mean. Do you want the whole list of maps?
Message 10 of 15
cikho
as i expected.
run it using the intel integrated graphic card.
old geforce drivers have problem with showcase since release 320.19.
http://forums.autodesk.com/t5/general/problems-with-nvidia-drivers/m-p/4337646/highlight/true#M1200
if it works, try to:
1. upgrade drivers to the latest (not tested)
2. find driver version earlier than 320.18
Message 11 of 15
in reply to: cikho
I add a view from NVIDIA GeForce.
Now my driver is up to date.
But Showcase crashed again with the same error.
Message 12 of 15
cikho
you have to set the default graphic card for showcase to the intel card..
use the nvidia panel to do that..
i'm quite sure it's the geforce driver not supporting showcase that causes the crash..
Message 13 of 15
in reply to: cikho
How do I do that?
Message 14 of 15
cikho
http://www.howtogeek.com/175281/how-to-force-graphics-options-in-pc-games-with-nvidia-amd-or-intel-g...
do the reverse, under preferred gpu select integrated intal graphic
Message 15 of 15
in reply to: cikho
I tried a several times but I think it failed. Got another update for my driver but Showcase isn't still working
