I am wondering if you know if Showcase supports Multi-GPU’s?
Will adding an additional Quadro card boost performance (e.g. frame rate?).
I understand that ray-tracing leverages on CPU speed and cores.
I’m interested in the frame rate and working with Inventor assembly files.
Solved by cikho. Go to Solution.
unless you already have the latest generation quadro k6000, i doubt a multiple gpu solution will be cost effective..
first, having 2 gpu does not mean that the total graphic "power" is equal to gpu1+gpu2 power.. it's a more complex calculation most of the time resulting in a less effective solution...
second, the cost of having 2 cards is probably higher than having a single one more performing..
if you already have the k6000, then a double k6000 system is probably the most powerfull solution you can achieve considering certified hardware, but, again, the cost will be so high it is better to understand a way to simplify your models, drop the poly count, reduce the N° of textures and optimize the shadows in order to achieve better framerate with the system you already have..
probably, if showcase could support latest gaming hardware like the titan family, there would be more degrees of freedom in hardware setups..
Having more than one card will do nothing for you inside of Maya. The reason is they can not share memory. Nvidia is working on a solution for this but for now it would be a waste of money. Now if you are using this computer to do high end effects inside of Nuke for example than yes adding a Tesla Card will improve the performance of the GPU accelerated features such as ZDepth, Glow, Rays, and so on.
FYI - I have a 1GB Quadro 2000 put in a 1GB Tesla 2050 and installed GPU-Z to see how it behaved and noticed that when working in Showcase, the Tesla GPU is working and peaks at around 50%.
If I turn on Ray Tracing though, it's all CPU and the Tesla does nothing for performance.
Only one graphic card is supported in Showcase.
Cikho is right..
You can look at these two video to see comparison videos.
and
Marion
