Hi all,
I am importing set of constraints from Model into showcase. It works fine. But, i want few things to be done with constraints. Is it possible to stop the constraint animation in process and run the other constraints ?
Also, i am experiencing some problems in animation. All constraints are interrelated. One component moves with another component and then moved component rotate with respect to another axis due to another constraints.
Now, whenever i am running these animations. Components moved to initial position before it moves due to another constraints.
Please advise me for above mentioned problems.
Thank you for the help and time.
Hi Jagan,
"I am importing set of constraints from Model into showcase. It works fine. But, i want few things to be done with constraints. Is it possible to stop the constraint animation in process and run the other constraints ?"
Yes it is. After importing the Inventor constraints you will have all the behavior related in Showcase.
You will have only to insert them in the storyboard as normal behaviors.
But , attention, you can do it only if those behaviors are not linked /relatem between them, otherwise you will experiment a deconstrution of your model.
If you have and want multi-movements constraints showcase model you will have to face it directly in Inventor.
You will have to link with formulas all the constraints involved to simulate your multi sequence actions and control all the animated constraint with a main driving constraint.
When you will success in this you can import that constraint in Showcase.
Admaiora
Hello Jagan,
i think this video i made should help you in your intent.
Admaiora
If your behaviors are ok, trying to rotate the scene you will use the way i have posted you will have no problem.
You don't have to rotate, scale, or moving your model if your model contains behavhiors from Inventor constraints.
You have to move/rotate the orientation of the space.
Admaiora
