Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Choppy image
7 REPLIES 7
Message 1 of 8
441 Views, 7 Replies
Choppy image
I do simple renderings using Showcase. I have used it at my last job and the images came out great for what i needed. I am doing the exact same thing at my new job but my images come out choppy. I typically render using Realistic+ visual style with anit-aliasing on high. For some reason the lines are choppy along with shadows. With both places I have not changed the settings, so they have always been default. Can this be something with my graphics card?
Tags (2)
7 REPLIES 7
Message 2 of 8
admaiora
Try this
http://forums.autodesk.com/t5/General/black-flashing-panels/td-p/5166419
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 8
in reply to: admaiora
Thats a helpful hint, but my issue is with shadows and the edges of the objects being choppy.
Message 4 of 8
admaiora
can you post an image?
Have you tried File>Setting>Performance and Quality> Automatic Quality Control  , setting it to an max level?
Admaiora
Message 5 of 8
cikho
try going to appearance -> directional light and shadow -> rise the quality of the shadow
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
Message 6 of 8
in reply to: cikho
the shadow setting worked for me, so thanks for that. The image still seems a little shoppy and blurry. I did this one at 1920x1080, resolution 2000, and Anti-Aliasing at high. My automatic quality control is set to high as well.
Message 7 of 8
cikho
1920x1080 resolution 2000 means nothing..
it means you have an image smaller than 1 inch..
go through centimeters..
like a4 format ( 21x29.7 cm) at 200 dpi antialiasing at maximum.
Message 8 of 8
in reply to: cikho
that worked better. Thanks
