I have created a video in showcase & some of the panels flash black as the video moves.
Is this likely to be a lighting problem, software problem or maybe a graphics card problem? (knowing my luck it is all of the above 🙂
Solved by cikho. Go to Solution.
Solved by leandrav. Go to Solution.
Solved by Christian_Garimberti. Go to Solution.
Try to set the CAMERA CLIPPING PLANES.
http://forums.autodesk.com/t5/General/Import-from-ACA-to-Showcase/m-p/5023322#M2041
File - Settings - Scene Settings - Distance from camera to near clipping plane
Tips in this video.
https://www.youtube.com/watch?v=PBMMg8PEPzU
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
clipping planes are planes associated with the current view which define the closest visibile distance and the farther one..
so the near clipping planes cuts every object/polygon which is closer than the specifyed value, while the far plane hides everything which farther, always based on the current point of view. so when you move also the planes moves and cuts different objects in different positions.
