I have a scene where bevaiours play in Hardware rendering with almost no problems.
I can render the scene in Hardware mode and the behaviours are played along.
But if I change to raytracing mode behaviours won't play and won't render.
Ant ideas?
Solved by MarionLandry. Go to Solution.
Have you try to save the movie?
Maybe you can't see the behavior in raytracing in realtime but it can really acting well during the animation.
Admaiora
Can you post the zipped scene?
How long is the movie?
What raytracing stop number did you choose?
Admaiora
Cross sections are not supported in ray traced mode.. that might explains why..
if you behavior is to animate a cross section, then it's normal it's not working in Ray tracing mode.
Perhaps if you explain a little bit what the behavior is triggering, it will help.
Behavior are ment to be used in presentation mode or in a story board slide. if you are exporting a movie from a SHOT, that can't play the behavior. Make sure you are exporting the movie from a storyboard slide in order to include the behavior.
Hope this helps
Marion
