Hi All,
I have one object which contains 4 planes as elements parallel to each other. Each plane has the same image with alpha.
Showcase displays only the last plane with the image and the front planes looks to be behind.
Because is hard to explain the problem i have attached two images.
The first image shows from left side the object, and the second image after i have rotated the viewport a few degrees to the right.
Does anyone knows a solution to this?
