Guys, i'm getting a problem with a end user application of Scaleform and, to come here, you guys must realize how sick of research I am.
The thing is, i play TERA Online and I know they use your UI Toolkit in the game.
The problem is, theres a known bug which makes the FPS in the game lower A LOT (~-25 fps) when UI is opened. Theres an option ingame to hide UI (for screenshots), so in the second i turn your UI off, the FPS increases a lot.
Theres several posts in support of TERA about this problem, but noone found an answer so far.
Some theories says Scaleform have a bad performance in AMD CPUs/GPUs.
Things that DOESTN are the problem:
- Poor PC
- Background applications burning memory
- Connection issues
- Lack of update (nor windows, nor flash, etc)
Does anyone here had problems working on AMD CPUs/GPUs or any other game with scaleform?
Any workaround?
