What are the rules for switching computers for fusion if my current computer is not handling the program?
Solved by innovatenate. Go to Solution.
The subscription is tied to your Autodesk ID. You can use it on as many computers as you'd like. Since your data is stored in the cloud, there's no need to worry about moving your data either.
All you need to do is install, sign in with your Autodesk ID, and enjoy!
Let me know if you have any questions.
I don't think that it matters. Your subscription is based on your user name and active when you log in to fusion. So you could go to any computer that has fusion and login and use it as long as your subscription is current with autodesk.
Then why does it says 3 computers for single user at the following link? and what if I have to replace one of the three computer with another computer?
