Spline handles appear to be under the spline, making it a pain to click on the handles when you're trying to do an edit.
https://screencast.autodesk.com/main/details/e066ba45-489b-4f2d-8301-2c9d078086e1
Solved by taylor.stein. Go to Solution.
Hey Luke,
I agree - spline handles can be difficult to select at times. One way I tend to work around this is to change my selection filter to only "Sketch Points." With this selection filter checked, you can click on spline points, and easily drag around the ends of the spline handle without accidentally moving the sketch curves.
Perhaps this is we can add to the idea station?
Let me know if this helps,
Taylor
Hey Taylor, good idea. Perhaps it is ideastation worthy. Do you guys add these ideas internally even if they dont end up in IdeaStation? Thanks!
We do, but it's always helpful to have a reminder on the IdeaStation that the request initiated from a Fusion 360 user!
Taylor
Hey Luke,
I understand how this can be frustration, especially when working in a small area with a lot of geometry. What would be the ideal behavior that you'd like to see? For example, would you like to hold a key down to limit your selection capabilities to handles?
Happy to help,
Taylor
Thanks, Luke - I'll make sure to share your feedback with our UX team!
Taylor Stein
Fusion 360 Evangelist
