Hello everybody,
Could you give me some advice for the best practices when I have one big project with 3 different blocks. They have common basement and different relative level zero for every block. In order to have correct relative levels for every block, how do you think is the best way to approach this in Revit. With Revit links and every block on seporate model. Or to use somehow one model. But if I put new coordinates as level 0 for one of the blocks, than level 0 for other block will be for example -1.21. And than I can't use the correct relative levels for other blocks. Please help!
I think you will be more successful in getting a well thought out answer if you post the same question on the Revit community forum:
http://forums.autodesk.com/t5/Revit-Architecture/bd-p/133
If I knew anything about it, I would definitly help, but the pro's will be at the link above! Hope this helps.
James
