Previews black shaded
2 REPLIES 2
nkloski
441 Views, 2 Replies
Hiya...I just uploaded about 8 .igs files into a new Project.  When I am in the Autodesk360 online hub and I click on the file to view them in the spinny viewer some of them are nice and white with shadows highlighting them as I spin them around...and some are dark black with some white highlights as I spin them around.  The black models I cannot discern any sort of lines on them, and they are basically not something I can show to others.....does anyone know why this is happening?
Nick
Nick Kloski
Tags (2)
2 REPLIES 2
innovatenate
in reply to: nkloski
This doesn't sound like the correct behavior, but I note that I am getting a similar issue. When I upload CAD data to the previews for some file formats appear to be pretty dark.
I note that if you find those IGES file in your data panel in Fusion 360, right click on them and select Create Fusion Design, the previews are much brighter since the file is converted to a native Fusion 360 file.
This may be used as a work around solution in the interim. I will report this to development. Thank you for reporting this!
Cheers,
Nathan Chandler
Principal Specialist
nkloski
in reply to: innovatenate
Awesome, thanks!
Nick Kloski
