Opening a file from my project gives me error 404?
10 REPLIES 10
Message 1 of 11
grabberr
799 Views, 10 Replies
So...just as the title states,
Yesterday, I uploaded a file from my home computer and did some editing in Fusion 360.
Then I added some CAM toopaths, and saved the file. waited til it uploaded and closed fusion 360.
Today, I am at work and the file won't open?
Fusion 360 says: Opening Document but it just  spins and eventually after close to 10 min it says error 404.
I don't think its a hardware issue since my home computer is far less advanced.
Help?
10 REPLIES 10
Message 2 of 11
grabberr
in reply to: grabberr
Here is jpeg's of the 2 errors (a new one just happened)
Message 3 of 11
innovatenate
I'm sorry to hear you are having difficulties accessing a file in Fusion 360.
When this occurs, would it be possible to share a copy of the Diagnostic log files and post it to this thread?
Diagnostic Log File.tiff
If you restart Fusion 360, does the issue continue?
Also, the JPEG you mentioned were not attached in the last post, would you mind re-posting those?
Thank you,
Nathan Chandler
Principal Specialist
Message 4 of 11
grabberr
in reply to: innovatenate
Here they are
Restarting Fusion made no difference.
Message 5 of 11
shrirangmoghe
Hello grabberr,
Can you invite smoghe at autodesk dot com to the project?
I can try to fix the issue that you are facing.
Shrirang Moghe
Fusion 360 Architect
Shrirang Moghe
Fusion 360 Development
Message 6 of 11
grabberr
in reply to: shrirangmoghe
Done!
Thank you for your help!
Message 7 of 11
shrirangmoghe
I am glad it worked. We should be addressing this soon.
Sorry for the issues 😞
Shrirang
Shrirang Moghe
Message 8 of 11
andrewh
It works now!
Thank you
Message 9 of 11
PioneerSS
Hello
My school is using fusion 360 was working but recently after the update the error 404 appeared on all the computers. Please help. Attached is the diagnosic file. Could not find the updated full version of the fusion 360.
Ignatius
Message 10 of 11
PioneerSS
in reply to: andrewh
PS
Also tried to open up the fusion in admin account but did not update to new version. must i reinstall again?
Message 11 of 11
innovatenate
in reply to: PioneerSS
@PioneerSS Is this occurring on your school's computer lab's? If so can you check the  Help > About dialog to see what build your are running? The current build number is 2.0.2079.
If so, you may need to request the IT administrator to update Fusion 360 to the latest version. I hope this helps.
Nathan Chandler
