As we went live with the Jan update we quickly found out that we had an incorrect config file for the MAC. So we pulled the update to fix it. We have a fix for it and working out when to release the update. Will provide an update shortly.
Sorry for the convenience.
Prabakar.
Hi Everyone,
We apologize for the downtime this has caused each one of you. The issue is a MAC ONLY problem and only for anyone that took our update early today. If you have taken the update and on the MAC please follow below step that will help you get back on track.
The login should now start working. Please let us know if this did not work to resolve your Mac issue.
Once again we apologize for the downtime.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
We are actively working to get the update out as soon as possible. I will update this thread when i have the exact time.
However, if you had already updated earlier this morning and on a MAC (Only) – there are two choices:
Autodesk Fusion
Join Fusion Insider
How would we know if the update was applied? I was prompted to restart Fusion 360 last night but never did so. Fusion 360 remained open overnight, and I continued to use it up until it crashed a few minutes ago.
Autodesk Fusion
Join Fusion Insider
Has the update happened for the PC version? I m not getting a banner or any notice about updating when I open Fusion. Current version number shows to be 2.0.1365
Autodesk Fusion
Join Fusion Insider
Subscribing for updates
The January update is now live. To pick up this update please close the application and restart. Some may encounter an issue where the application does not restart automatically after the live update. Once you start it manually you should be good and on Build 2.0.1403. This update is for both Windows and Mac but NOT our Mac App Store users. We will get the Mac App Store users to the current build in the next few days.
Thanks for your patience while we sorted out the issues from yesterday’s deployment.
Autodesk Fusion
Join Fusion Insider
