Is there a way to select the edges around a face or chamfer from a face
14 REPLIES 14
Message 1 of 15
highfreq
1639 Views, 14 Replies
I've pulled fairly complex sketch and want to bevel or chamfer the edges of the top face, it looks like the only way is to laboriously select every edge.  Is there something I'm missing?
14 REPLIES 14
Message 2 of 15
marshaltu
in reply to: highfreq
How about use region selection?
Marshal Tu
Fusion 360 Developer
Message 3 of 15
@marshaltu that would be fine for an object as simple as a box, but more complex geometry that has many other features the selection window would grab unnecessary items and chamfer those, as well.
Message 4 of 15
So, please attach your model so we all know what you are trying to do.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 5 of 15
Sorry. This is under NDA, but I can answer questions you have about my statement.
Message 6 of 15
westd1
Same question. This is my model. Basically a cookie cutter and would like to chamfer the top face along both edges for a sharpened/ thinned face
Message 7 of 15
westd1
in reply to: westd1
Just occurred to me I could do an angled extrusion off of the face... which would probably give the result I want.
Message 8 of 15
westd1
in reply to: westd1
okay I crashed fusion
Message 9 of 15
westd1
in reply to: westd1
Yeah that definitely won't work for this complicated of a shape that has inner and outer angles.
Message 10 of 15
g-andresen
in reply to: westd1
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 11 of 15
westd1
in reply to: g-andresen
Fusion file attached
Message 12 of 15
g-andresen
in reply to: westd1
Without working on the contours (softer transitions) this will not work.
At these and numerous other points, self-intersections occur that prevent the operation.
günther
Message 13 of 15
westd1
I'm working off a logo so I can't make major changes, but some of the very sharp edges are just from offsetting the path in Illustrator. I don't suppose you know of a smoohing technique so that I can avoid identifying every stray inflection point?
Message 14 of 15
g-andresen
in reply to: westd1
take a look at the file.
> Converted to Bezier and reimported to fusion > extrude +taper > extrude/cut  inside
günther
Message 15 of 15
westd1
Thanks! I'll check it out
