I'd like to put my model into another like him following Assemble->Insert->Retrieve Model
http://youtu.be/_I-tvWeGpm4?t=4m44s
But here's my screen.Where "Insert" has gone?is this the only case of me?
i'm sure it could be found until last month.confused...
Shingo
Solved by hisashin0829. Go to Solution.
Solved by herzinj. Go to Solution.
One option that you now have is to open up the data panel (as if you are going to open an existing model up) and just click and drag it into the work area. This will insert the model into the current workspace that you are working on.
James
For Mac,I could choose "Insert" it by right-clicking model.Thank you so much!
Hi Shingo,
yes, it's right. Inserting model throught the Drag&Drop isn't supported on the MAC OS right now.
Regards
Roman
