Considering both are Autodesk products, how does one go about loading a 123D file such that it is a native Fusion file?
Solved by Bud_Schroeder_ADESK. Go to Solution.
Hi Sanguish.
Thank you for contacting us. You have posted your question in the A360 support forum, I would like to refer you to the Fusion support forum where they would love to hear more about this idea and perhaps they'll also be able to share with you their thoughts or plans around this.
The Fusion support forum can be found here: http://fusion360.autodesk.com/community
Ilai Rotbaein
A360 Team
Thanks Ilai for jumping in to help. Scott, I'm going to move your question to the Fusion 360 forum.
And it looks like you posted to Fusion as well. Here is a link to that post.
http://forums.autodesk.com/t5/general-fusion-360-questions/import-123d-files/td-p/5426462
Hope this helps get you pointed in the right direction for getting help.
